Simple question...
Is it possible to put a motorized flip out screen in a 91-93 Caprice or are there clearance issues with the dash?
I was looking on car domain to see if anyone had a motorized screen an so far it appears the answer is no because I couldn't. So if you know, let me know
I can't remember which screen, but we did put one in a '93 at the shop. Although it will have to be bumped out.
We were going to try to move the a/c controls, and put it there and place the a/c controls where the radio was, but I've got to find a longer cable. Other than that, it should work great.
O
ive seen the ac controls swapped with the radio spot. was going to try it myself but i dont want to run into any issues where i would be without my radio for extended periods of time. i need my music. it would just be getting the vacuum lines and the heater cable up to the radio cavity and then the mounting of the controls that would be the bitch. moving the radio down would be the easy part.
