Try this to start
Find the beam switch on the left side of the column part way down towards the floor. ( closer to dash)
There should be power at the tan wire while on low beam.
If you don't have a meter or test lamp , stuff a short wire in both the tan and yellow terminals.
Also, is there a noticeable "click" as you operate the lever?
There might be a mechanical issue between lever and switch
Super Moderator
I had to replace that switch, it's easy once you lower the column. Test the switch with the column down, though, the mounting is slotted so you can move it so the switch engages fully.
