When I shut down my 94 all the interior lights stay on! The only way to get them off is to pull the fuse. Can somebody please explain to me what is going on.
Thanks for the help guys ;)
I would say pull out your door pin switches one at a time and disconnect them. Sounds like one of the wires may be grounding.
Check the harness that runs under the carpeting by your left foot. I had a similar problem a few years ago and fixed it by cutting a length of about 8 inches of 3/4 inside diameter heater hose and wrapping up the part of the harness i mentioned earlier. Those wires can get damaged just like that little patch of worn carpet you have under your left foot and sort out against the floor pan.
Good luck!
