There aren't many gauges that will read 1200 PSI, Boost and vacuum is usually 0-40lbs or less. I'm about to bite the bullet for a $200 autometer electric pressure gauge, you can get the mechanical for less than $80.
no other gage. boost only goes up to 100psi in one gage I saw.
Gage are also built for certain fluid/gasses....
IE if you try to run a boost gage with oil pressure, chances are you'll have fluid all over u, since the gage isn't designed to handle hot fluid. ;)
So don't try it.
get the one i told you about that go onto the bottle adapter, its cheaper
741-15910 -04AN Adapter, 0-1500psi, 1-1/2'' Dia., Blue Face Gauge
$39.99
jegs.com
