1 - 12 of 12 Posts
D
I'm finally going to replace my factory system in the Impala SS with components I stripped from my wrecked Monte Carlo Z34 and a new head unit.
I'm considering the Nakamichi CD-45Z or the Eclipse 5442(5441). The Nak retails about $450 vs $499 for the Eclipse. And actually, last years Eclipse (5441) is moving for $329 (and I would likely be able to get it for $300 at an authorized dealer with standard warranty).
I went to a couple places, one of which was a shop that sells Naks, McIntoch, and Eclipse, so they seem to focus towards the higher end. Interestingly, they were pushing the Eclipse over the Nak (this store didn't have the Eclipse 5441 close-out sale). From the sales perspective, I can see why they would want to sell the Eclipse since it costs more and they are out of stock on the Nak's (which take awhile to order, apparently Nak is having some supply/shipment problems).
They both have 3 pairs of RCA outputs
To me, the big selling point in the Nak is the 20 bit DAC. I haven't had the opportunity to hear a 20 bit DAC in a car stereo application, but I have heard them in High-end home stereo CD players (typically a burr-brown DAC), and they really pick out subtle detail that 1-bit DACs miss. I like the clean look of the Nak, and the minimalist approach to controls. I like removable faceplates. On the downside, I've heard that Nak can skip easy on CD-Rs and on scratched CDs (more so than other HU's). Also poor radio reception. I have an AT Flowmaster Cat-back and RAISS intake; so does that plus road noise effectively mean the detail and quality the Nak lets through will get washed out anyway?
The Eclipse 5441 appears to be a bargain at $300-$329. It has 5V output and low impedance (compared to 4V on the Nak, unknown impedance). Subwoofer controls on the face. Large display, motorized face. On the down side, it is a bit more flashy than the Nak (though not as flashy as other HU's), 1 Bit DAC, and non-removable face. Supposedly, Eclipse's security feature "ESN" locks/disables the unit , but what prevents some stupid punk thief from stealing it and messing up my dash anyway? Anyone know if this is really an effective theft deterrent?
This head unit will be feeding an older Kenwood 646 4 Ch amp (RMS 25W per channel into 4 ohms). This would be the lowest quality piece of equipment in the chain. The Kenwood amp will drive 5.25 and 6X9 Eclipse Point-Source speakers. I also have powered a/d/s subwoofer. It's a ported enclosure with an 8 inch driver and an integrated 80W amp. Overall, this system is not going to be very loud, especially in the Impala. In fact I hope I will be able to hear the subwoofer (the sub and kenwood amp were first purchased for the Beretta Z26 I owned prior to the Monte…great fit for the smaller Z26).
Future upgrades will involve replacing the Kenwood amp with something of more power and better quality (along the lines of 10W per ch) to get the most out of my HU and speakers, and of course a larger subwoofer. Don't know yet if I will go with a 5 channel amp (…like a Zapco something or other the high-end guy recommended) and ditch the Kenwood, or if I will just get a new 4 channel and try to use the Kenwood for the sub drivers.
Any comments on the Nak vs. Eclipse issue? Thoughts on future upgrades or things I should do with this initial install that will help with future upgrades?
A
Whoa!!
I didn't know that Nakamichi was till around.
When I think of them I can only think of bad azz tape decks in the 80's for home and car audio.
D
In home audio electronics, performance/quality wise, Nakamichi competes with the likes of High-current varieties of Yamaha, Pioneer Elite, Top-line Sony's, HK, Denon, Sherwood, Marantz, Rotel, and NAD. Basically borderline mass-market/entry-level high end.
Anyway, back to the cars!
E
....I'd go with the Nak.
My Clarion has a 24 bit D/A converter and it sounds great!
Just my $0.02.
Good luck!
never had a nok,but i do have a eclipse 5303 and iv'e never had a problem with it. but its up to you.
In a car environment (unless you really take everything to the "next level") .... yea, like me :D you won't hear the difference between the 2 DACs.
Both are excellent head units.
J
I love my eclipse 5506 unit. Different model but the only thing I dont like about it is not having the detachable face. About 6 months after installing my system it got ripped off. It was never recovered even though it has a traceable serial number, but I did recieve my shiney new one (even the newer model for that matter) about a week after the incident from Eclipse. I'm alot more aware of my BOOMING since then. Justin
Do either of the 2 companies make a 1.5 din head unit to fit in the stock dash hole?
D
From my research it appears that they only have DIN units. I saw a picture of a slick Eclipse head unit install. It was an S-10 with a flush mounted unit. It had a glossy black (I think it was black plexiglass) trim piece all around the head unit. (there's an Impala SS with similar concept, only with a Sony ES unit and a duller finish on the trim). This made the DIN unit blend really well into the 1.5 DIN opening.
Going into this, I really thought I would be getting the Nakamichi. However, the pro/cons seemed to favor the Eclipse 5441, so I'm going with that. Guess I'll save the critical listening for when I'm at home. Hope I don't end up regretting the non-removable faceplate issue though...I think I'll need to start using the shade in the windshield more often to keep the inside dark.
A
I have an Eclipse 5342R in my '93 9C1 and it sounds great, I think -- even as the only audio upgrade!
As far as security, just get your windows tinted and nobody will even know it's there. The place where I work isn't in a bad neighborhood per se, but several cars have been stolen out of the parking lot and many more have been vandalized, but my 9C1 has never been touched. (My windows are 20% transmission, btw.)
D
<BLOCKQUOTE>quote:</font><HR>Originally posted by andrew9C1:
<HR></BLOCKQUOTE>
I'm mostly covered in this respect. Too bad it's California where I'm not supposed to have my front windows tinted (though I see lots of cars that way). I bought the car with about a 40%ish tint all around. I had the tint removed on the back 5 and replaced with 6%. It's that reflective black/charcoal color...its mostly blackish but not quite under certain lighting conditions at some angles. (guess this is a post for another forum area)
1 - 12 of 12 Posts
