My friend is puting 4 plugs in pass. side of my 95 wagon for me,I put the 4 drivers side last summer(NGK TR55,V power). I also have a box of DELCO#41-906, How do these plugs compair. Should I change plugs Oldhead
Agree. Changing plugs are easy - well compared to changing wires anyway. Get the friend to redo your earlier work with all-same plugs.
DO NOT mix brands of plugs. I also would keep the NGK's. I've ran many different brands (and heat ranges) over the years in different vehicles and NGK has been the best plug by far.
I am currently running the NGK Iridium plugs a d have had them installed for about 5 years now with no issues. I do pull them and check them on occasion.
Hi
Some of you don't understand when he put in the 4 NGK they will be all NGK What I am asking witch plug is better? Oldhead
Yah I agree it's pretty straightforward. You did half of one brand last year and it sounds like you can either finish with the same on the other bank now, or do a do-over with a whole set of the revered ACDelco. If you thought enough to get a set of them on purpose then it's just a matter of asking whether your freind is willing to change 4 NGK to match the other bank, or do all 8 in a new brand.
You're never gonna get credit for the used 4 you did last year, but you might get a refund or at least store credit if returning all 8 of those ACD.
If the NGK are the right heat range I say pay the friend just the one beer to do the other 4 with NGK and return the ACD, but others favor American over another brand.
Hi
Job finished,All NGK, Sorry some misunderstood, I would not ever go with 2 brands Oldhead
