F
Ok here is my problem, I got a place where my car bottoms out... its at stock ride height at the moment but will be around 2 inches lower in the next month...
What can I do to raise the car so I dont bottom out? It needs to be something like airbags or something that I can inflate and let the car go up to like 9 inches then come back down again... any ideas?
9 inches thats kind of a lot if you are going to drop 2 inches more, you can use gabriel air shocks for the rear, if you want to do it manually an the cheapes way, or more expensive way with air bags with a air compresor with cotrols in the cabin, they have a kit for the front an back,
A
If the "spot" the car bottoms out is not your school, driveway, work entrance, or favorite strip club entrance, then I say just go around.
It sounds like a lot of work to get around one place that is causing you problems!!
B. Currey
F
expensive?! maybe. thats what I get for driving a land bound ocean voyager
F
Come on guys =( I only need a 4 inch lift any ideas?
If you want to raise your car, but you also want to lower it I'm thinking airbags are your only options...
