I hope someone can give me an idea that might stop the dripping condensation in the passenger floor of my 95 RMW. Yes, I have the elbow on the snout that sticks out of the firewall. Yes, the pan is sealed with 3M strip caulk. The pan itself is not leaking but, somehow water seeps down the front of the pan above where the snout is and drips from the rubber onto the floor. I have had this pan off no less than 7 times and even changed it out for one in excellent condition with the same result each time. Today I made sure the part of the condenser just above where the leak is had plenty of rubber insulation all around it and was sure this would solve my problem. Wrong again. In the climate I live in it makes this problem worse because of the high humidity and high temps. If anyone has any constructive thoughts on how to fix this issue I would be greatly indebted. I also posted in the HVAC section. Thanks, Glenn
