Hi, Been a member for over 10 years, I need help with springs, this is my first post.
I searched everywhere for this information, decided to finally post;
I have a 96 Impala SS, its LSX376 swapped, Magnusson heartbeat SC, 4L85E, oversized brass radiator, all this adds a bit of weight and has caused the front to dip by 1.2" from stock, the current springs are "Stock Height Springs" purchased new from Street Trends before they closed about 2-3 years ago.
The front springs height measurement from the ground through the center of the wheel is 26.6" I know factory Impala sits around 27.8, I'm lower than stock by 1.2".
FYI: The rear is sitting at 27.5" which is fine.
I read on this forum that front Moog 584 is 0.5" higher than stock with a similar spring rate to factory. Caprice springs could be an option, I read they are 1.5 inches higher than Impala which is too high.
Does anyone know of another spring that would add about 0.75" - 1" over stock ? Worst case I could go with the Moog 584 and gain 0.5".
Thanks so much everyone, appreciate all the help!
