I'm wondering were is the starter wire under the column? Also pick what it looks like under there. Cause I think the wire came undone when guy put on alarm in. He said he soldering the wires all symptoms come to.the wire came lose. Cause starter won't do anything I checked everything else. Fuses,relays starter good.
Sounds like this is related to your other thread....
http://www.impalassforum.com/vBulletin/showthread.php?t=1259953
...you should probably post this there and not start a separate thread for the same issue. You may get better response in your original thread and there is a chain of info there for others to follow and possibly help.
