Hi there! I am trying to pull my antenna out of my 1991 caprice, however I cant seem to get my wheel well to pull out far enough for me to block it open. Yes, I have pulled the screws holding them in, but it just doesn't seem to want to budge more than a half inch... Please help! Any ideas?
Thanks in advance!
-Chris
I believe I left an instruction write-up for you as a PM. The only other issue you might have is that the wheelhouse sometimes catches on the frame, or other edges when trying to pull it down. As long as you have all possible screws/bolts out, you should be able to wrangle it to where you can get a 2X4 between it and the body. The further you get it out of the way, the easier it is to remove the antenna.
