I have the 12 way fronts and blazer console already installed but am now tackling the rear seat. I do not have a welder nor easy access to one so modification to the rear seats to make them fit is less doable.
From what I can tell, the rings holding the fabric to the frame will need to be cut and replaced and the foam on the bonnies cut away to reveal the frame. What else holds the frame to the "seat" ? Also, is there support for the headrests contained in the frame?
I just laid the back portion of the seat against the rear and marked where the brackets are... Then cut away the foam along my markings and bent the seat frame with my hands (really fuggin tough.) But after an hour or so It was pretty okay. I still need to adjust a few things and try to bring that back piece down a little.
