Vendor
visit C3 FAB RACING FOR THE BEST REAR SUSPENSION FOR YOUR B-BODY CHEVY!!!!
LINK BELOW
http://shop.c3fab.com/1991-1996_c16.htm
1 1/2" DOM ROUND TUBULAR-FULLY ADJUSTABLE UPPERS AND FULLY ADJUSTABLE LOWERS , STOCK LENGTH OR 5/8" EXTENDED! CENTER UP YOUR REAR WHEELS WITHOUT ANY DRIVE SHAFT ISSUES!!! THATS HOW WE DO IT !!!!
14MM BOLT KITS AND POLY REAR HOUSING BUSHINGS ALSO AVAILABLE NOW!!!!
On your site,
where you pick your options, what does sway bar provision selection mean?
Vendor
On your site,
This means if you are running a sway bar we fully weld sway provisions (sleeves)on your rear lower arms to mount a stock or aftermarket sway bar . Thanks, Mike G.
Vendor
Sway bar app
If you use a 91-96 impala/caprice/wagon rear control arm setup like the ones we offer, and a stock or aftermarket sway bar for the same b-body years as above ..... There is no reason why it should not work !! It's just the matter of the customer wanting to make the upgrade on his/her wagon like yourself !! Thank you !
Mike @ C3 FAB .
You realize that the wagon rear control arms are spaced farther apart from each other, vs a sedan. You can't fit a stock Sedan sway bar on a wagon, in the stock bolt holes location. They have to be pushed forward, or have an adapter plate.
