i just installed a flipdown moniter and a dvd player,i can't get the picture to show the sound work ok,but the picture jump up and down like its set on the wrong station,what do i need for this do i need a brain for the monitor,thanks
Make sure your monitor setup is set to video input and not TV and the only other thing would be NTSC format and not PAL. Also check to make sure you're not connected to the digital output from the DVD and are plugged into the analog video out. ;)
it don't have a tv or dvd button on the monitor,i thought that was the problem and try to find the selecter,but could'nt find a switch just ch, vol clr,tnt etc.
Monitor would seem to take only straight video in. Check the connection on the DVD and make sure your connected to the video out(composite) and not the digital out.
