i need to know what rca wires im going to need to connect my two amps one being a rockford fosgate 200a-4 (hi's) and the other being a hifonics bxi2006d (subs) and how much feet to connect both to the trunk ....thanks fellas
OR, he could just get a set of 4 chan RCAs, OR he could just daisy chain the amps(1 long rca an 2 shorter ones like 1ft a pop connected to the in and out of the other amps)
If you want to control everthing with the deck you will need 3 seperate runs. you will want to keep them away from power cable unless you buy shielded cables. The length depends on how you plan on running them.
so 17 feet four channel rca wires for my four channel amp and what wire would i use for my hifonics bxi2006d amp ....would it be two channel if my amps mono and only going to be used for bass
