·I'm about to install a new set of Grob-Till GT Rotors. I'm also planning to install new wheel bearings with the rotors, and have both inner & outer bearings and seals.
Upon inspecting the GT Rotors, it turns out they already have the bearing races in them, and the races are coated with the same gold-colored (zinc?)coating as the rotor. They had the races in them when they treated them.
Question: Should I pull the races from the rotors and install the new ones, or can I just put the new bearings in the races already in the rotors? (The surface of the races in the rotors is NOT as smooth as the new races with the bearings).
If I bought new AutoSpecialties or even GM rotors, would they come with bearing races already installed?
Makes me wonder about the GT's, and why they would have bearing races already in them...
Thanks for any insight.
Tony Hill
Tony Hill
