So guys I need some help I have a 1994 Chevy caprice with the 5.7 in it. Got the car a year ago and just now have had to time to get to it. I noticed the car was running sluggish so I changed The spark plugs, spark plug wires, distributor, and fuel filter. So after that still was having problem so a friend of mines suggested changing the fuel injectors. So I changed them now the car is running rich and the fuel pump is engaging and won't go off. Can someone give a few suggestions to look at or change before I send the car to the shop just to find out what the problem is.
Sent from AutoGuide.com Free App
This happened right after you installed the new injectors? I'd go back step by step to make sure everything was reconnected properly/isn't pinched or kinked/seated properly, etc. etc. etc.
If that failed, I'd reinstall the old injectors to see if the problem follows. Chances are, when you tear everything down, you might see something you missed or doesn't look right.
