1 - 9 of 9 Posts
New, never run. Several years back I worked with Victory Racing Engines in Michigan to put this engine together. Unfortunately, I was never able to finish the car it was meant to go into. The engine has been sitting in my garage since being built. Condition on all of the parts is new or like new. I just pulled the oil pan off to inspect the bottom end and it looks the same as when it was first built. Build sheets are included in the sale.
Asking price is $6500.
Located in Houston, TX. Local pickup or buyer arranges pick up with shipping company.
Photos can be found here: https://imgur.com/a/YRgZpAp
Parts included are the following:
Bottom End
- Seasoned LT1 block
- Callies 4 bolt billet splayed main caps
- Callies 3.875" stroke Racemaster crankshaft
- Callies Compstar 5.85" connecting rods
- Diamond -10.8cc pistons
- Total Seal rings
- Clevite main and rod bearings
- Cloyes double roller timing chain
- ARP main studs
- Titan Gerotor oil pump
- Bronze oil pump drive gear
- Milodon oil pan w/ stock windage tray (modified to fit Titan pump)
- Stef's aluminum oil pan (custom designed for 94-96 B-Body fitment)
- Front mounted oil filter adapter (can be removed to use stock mounting location)
Heads/Valvetrain
- AFR 220cc heads ported by Lloyd Elliot (58.4cc chambers)
- ARP head studs
- Comp solid roller camshaft (248°/248° @ .050" duration, .414"/.397" lobe lift, 106° lobe separation)
- Comp 943-16 Pacalloy valve springs
- TD 1.6 ratio offset shaft mount rockers
- Crower solid roller lifers
- Trickflow .080" pushrods
- Sheet metal valve covers w/ K&N breathers
Intake
- Ported LT4 intake manifold w/ welded runners
- Holley 58mm throttle body
- Summit Racing 42 lbs/hr injectors (fuel rails not included, had a set of AN ones that got used elsewhere)
- Modified Optispark (high voltage components removed)
- LTCC ignition system w/ LS1 coil packs and billet mounts
- Taylor plug wires
Accessories
- ATI Super Damper
- Meziere electric water pump
- SFI flexplate
- Powermaster XS starter
- Stripped down B-Body wiring harness included
- Include miscellaneous gaskets to finish up assembly, may require a few more
Asking price is $7500.
Bottom End
- Total Seal rings
- ARP main studs
Heads/Valvetrain
- ARP head studs
Intake
- Taylor plug wires
Accessories
- ATI Super Damper
- SFI flexplate
Would this engine be California legal for emissions tests ?
I’m concerned about the intake.
I’ve been wanting to put one on my SS’s LT1 but even though it’s designed with an EGR valve location, my understanding is the intake is not CARB D-269 or whatever certified.
Can you shed any light on this.
I would love to drop that thing in my Impala...
Not tell em it’s stroked...
Thank you for any information you can supply...
I’d hate to buy that intake, out it in only to find out some smog technician is gonna tell me it’s a no go...
Considering they won’t even let me remove my useless and disconnected air pump, I’m so gun shy to mess with any of the intake or exhaust systems that I haven’t done hardly anything to substantially increase performance.
The TSA says to disable it, but the smog referees and smog stations tell me i can’t remove it completely and that it has to stay in place.
Their Justification is, the TSA says disable, not remove.
Even though it no longer does anything but keep 29 lbs of a useless anchor on the car and usually in my way of anything I have to do with the front part of my engine, and it’s actually a potential future source of exhaust leaks that would seriously effect the emissions, they still won’t allow me to remove it.
Aaarrrggh....
I hate California...
11.5:1 is static compression ratio. I don't know any details on how California does emissions testing but I would be very surprised if this engine passed it.
1 - 9 of 9 Posts
