1 - 11 of 11 Posts
I replaced my broken factory antenna with a cheap Autozone replacement but the reception and fit was poor so I upgraded to a "Eurostyle" antenna from a late model Saturn wagon (pull a part-$3).
I mounted it in the black plastic strip where the wiper motor protrudes and it fits well. I had to cut the antenna wire to remove it from the I spliced in a section of coaxial cable left over in my basement from comcast. The reception is stronger than the cheap antenna and I think the look is smoother. The antenna unscrews from the base so it will not interfere with anything flat on the roof.
For now I have plugged the factory hole with a small plastic plug painted white but will soon weld in the hole and repaint the top of the fender.
I like it looks like a big a** rc car just remember to unscrew it before you go in a car wash
It looks like you have a car phone.
Get them FORD hub caps off there man, they will spread their disease infested germs to your CW and make all sorts of bad chit happen to it.
+1 Take them thingz off maaaaaan!! Dont disrespect your ride like that. They may look clean but just dont belong. P.s not tryin to play you or your ride , just hating on ford lol.
1 - 11 of 11 Posts
