1 - 20 of 65 Posts
Hallo.
I developed new 10mm steel mounting plates to make possible use with modern trw calipers and parking brakes.
Wheel Tire Automotive tire Locking hubs Motor vehicle
Does wheel fits perfictly on axle without spacers? Yes!
Automotive tire Gas Circle Automotive wheel system Rim
Left with metal clip, right - factory clip )
200500
200501
Car Tire Wheel Vehicle Automotive tire
Does it compatible with 15 inch wheel stock caprice wheel? Yes!
Does it possible to install bigger diameter brake disks? Yes!
Does this rear brake disks are vented? Yes!
How many parts are "non factory"? Mountig plates, one 14mm usual metal clamp
Bolts: all metric 10.9 including mounting to flange
Does leg parkinig brake works? ... Same as usual...
Parking brake clicks: AAAAAdjustable! 6~7 clicks.
Does all parts are domestic buying: Yes! Everywhere.
Do i have antoher same kind kit with bigger pads? Yes, for 17 inch impala wheel disks. There another bigger caliper with bigger brake pads.
How long i develops it? 1year 9months.
Is that so difficult to develop? Yes, very hard, but successfull work. This is all considering that I have a family with two small children.
I do not make brake bolt mod at this time.
Quite a few hits of interest but no replies. It's sounding as though you've devised a bigger brake option when limited to 15" wheels, and even a similar new larger option than stock for 17". I recall someone else across the pond looking to combine and machine EU rotors/hubs/calipers to work with our cars. Yours appears to be a scratch-built all-new backing plate to take more current design brake pieces?
Show off more pics - if not still secret stuff. ;)
Forum Shaman
Is this mod more of a European thing? Is it difficult for you guys to get OEM parts?
I don't understand what the upgrade is, if the rotors are only 5 mm larger than OEM.
Yes! All-new backing plates laser cuted from scratch.
Yes, i devised a bigger brake option...
IIon Mask resting :)
Very well. It sounds like then that there was no such thing as a rear disc 15" car. If that's the case then a good hack.
And I was thinking more Dr. Eevil v. Elon.
  • Like
Reactions: 96Lt1civi
Discussion Starter · #19 · (Edited)
Opel Insignia rear calipers and ATE w221 vented brake rear disk: 300mm, thinkness 22mm.
As you "see", one center cable are not custom... this is FORD!! :eek: 🤦‍♀️ 😂
Now are you feel that all parts are readily available and EASY buyng? 😀
Thinking to sell mount brackets in USA.
In the photo, do not take into account that the plywood mount and the caliper with bracket are in red. Now everything is sandblasted, painted silver and mounted on metal backplate.
Tire Wheel Motor vehicle Automotive tire Automotive design
Wheel Automotive tire Motor vehicle Aircraft Tread
Vehicle Motor vehicle Automotive tire Wheel Tire
Wood Automotive exterior Gas Bumper Building material
Tire Wheel Vehicle Automotive tire Motor vehicle
Tire Vehicle Automotive tire Wheel Motor vehicle
Automotive tire Wood Bicycle tire Rim Gas
Vehicle Motor vehicle Automotive exterior Bumper Gas
200520
1 - 20 of 65 Posts
