I plan to purcahse a new steering wheel. I was wondering if they're any you guys had instructions or videos on how to install a new steering wheel on a caprice or impala.
Are you going aftermarket or similar replacement?
You need a steering wheel puller, #20 or 25 Torx, assorted sockets and a large ratchet (1/2 inch set), and depending on what you are going to do, you may need other tools.
The list includes a outside circlip pliers, soldering iron (maybe), wire cutters, 7mm socket, dremel with sanding disk, 10W 2 ohm resistor (or combination to make that value), as well as the adapter for the wheel. I may have missed something, but that is pretty much it.
