I have an ALDL cable. I downloaded Datamaster. I set datamaster up as per their directions for Windows Vista 64-bit version. I made sure Comport 6 is selected (USB) bot in the software and with the drivers loaded correctly. I went into the data executing protection and gave the software the exception that they needed (as per TTS).
When I begin to monitor is seems to work fine. Then the Data OK indicator turns red and says data error and it stops recording (I can post this if I knew how). Often when this happens the DTC OK turns to red as well.
It will record data for a few seconds and then seems to loose its mind and stops. It reset and does it all over again. VERY FRUSTRATING!!!!
Help!!
Help!!
