ISSCA Member and prospective members: Now is the time to get your registration in before the rates go up. The Vegas SShowdown registration goes up an additional $10 (to $70) and the Competition licenses also after June 1. The special room rate of $69 stops on May 28. Go to www.goissca.org to sign up now.
The big raffle of the 383 c.i. LT1 stroker engine assembly (built by Race-Prep Performance) will be available on the ISSCA site for 11 days starting June 1. This engine will be on display at the SShowdown. (Raffle Tickets are only open to active ISSCA members). Raffle tickets will be on sale at the Vegas SShowdown during ISSCA Registration at Sunset Station, from June 22-24, 2004. Raffle tickets are $10.00 each.
The Race-Prep Stroker engine assembly will include: Trick Flow LT1 cylinder heads, SCAT forged rotating assembly, Port-matched intake manifold, 4-bolt main upgrade with billet caps, High Volume oil pump, ARP fasteners, DynaTech distributor and Custom programming by Bryan Herter at PCMFORLESS.COM.
NOTE: The Stroker engine package is a "long block" and DOES NOT include:
PCM, injectors, fuel rail, throttle body, wiring harness, sensors , oil pan , accessory brackets or accessories, flywheel or flex plate, balancer (hub may or may not be installed), exhaust manifolds or headers. The winner is responsible for shipping!
We have some very large vendor and sponsor displays planned from the following aftermarket companies:
SPONSORS: Street Trends, Audio FX/ImpalaSSforum., Trans-Go, Race-Prep
VENDORS: QA1, Digital Race Photography, JAWSS Productions, Beach Cities Painless Dent Removal, Bryan Herter (PCMforless.com), Combination Motorsports, Jerry’sElectronics, ImpalaSSCarpet.com, JE Reel Drivetrain, ASI (Shox.com), Raybestos, and Kumho Tires.
If you want to chassis dyno your B-body while in Las Vegas, we have made arrangements with Silver State Motorsports to have your car dyno’d on June 24 from 8:30am-3:30pm with two pulls (with HP & TQ sheets) for $50. If you plan on doing tuning, you will need more time and it will cost a little more for the additional time/pulls, but they will take appointments for Tuesday, Wednesday and Friday (June 22-23 & 25). You will need to call ahead (702) 644-8756 to get time to do tuning. Their facility is conveniently located next to the LVMS drag strip at 6865 Speedway Blvd (Suite Q103). They also have nitrous filling capabilities, so you can fill up for your dyno pulls or for the drag strip that evening!
See you there!
Sam Martin
ISSCA Public Relations Officer
