Nitpick question.......
343 Views 1 Reply 0 Participants Last post by  AutocroSSer
I was looking over the Vehicle Classification form and had a question. In the final gear ratio change you state "Final gear ratio change less than 20% from stock (e.g. 3.42)" is 2 points, but "Final gear ratio change more than 20% from stock (e.g. 3.73)" is 3 points. Which gear ratio is this and how is the transmission taken into consideration? With my t56 and 4.10 gears, I am still less than 20% final gear ratio in first gear compared to stock. So would that be 2 points or 3 points against me? I am already in the "Modified" class by 2 points so this would have no effect on me, but it might matter to somebody else.
Thanks,
TOM B
It's based on rear gears, so you'd be 3 points.
You don't plan on running the road course in 6th gear now, do you???? :D
Note that the tranny itself also counts for points now.
