I'm in currently building and LT1 cast-steel scat I-beam 383 Stroker with hypertec 12:5:1 compression pistons with LE3 heads ,LE ported and Polished Intake manifold , LE custom grind motor/nitrous camshaft , with 3.90 gears and 9.5 3400-3600 converter 42lbs injectors , an will be tuned for either 91 or. 93 pump gas. This set up will be going in a 94 caprice wagon weighing 4600lbs and wanted know if a 150-250 wet shot of nitrous will be ok ? This a daily driver / track car
A lot of f-body guys running simar set cast-steel 383stroker set ups with spray as daily drivers for years too!
Related Threads
Chevy Impala SS Forum
1.9M posts
42.7K members
Since 2000
