NW sells a kit that has fuel & oil pressure safety switches, PLUS a provision to dump nitrous from the system in the event of a stuck nitrous solenoid. Does anybody know how this dump feature works and what triggers it?
And just how common is a stuck nitrous solenoid when running a filter?
Could you also reduce the risk by running two solenoids in series? - any issues with the 1000 psi trapped in the line between the two when they close?
TIA,
Pat
Hey Pat,
I had a stuck N2O solenoid once. No biggie, I just hit the bottle shut-off button. If you're not at WOT when it happens, the only thing to occur is a lot of bucking and shaking from the motor.
Another question for SSMOKEM and anyone else:
What are the pros and cons of the Nitrous Works throttle body plate versus a fogger nozzle in front of the TB?
How about a TB plate with the stream pointed forward? Would this help the disbursement on a forced induction motor?
Thanks,
Mav
