having trouble with trans not shifting from 1st to 2nd the first time you drive it for the day unless you let off the throttle then it will shift. also having trouble after driving the car the car for about 15 miles it will start to stumble and then throw a check engine light, the it will drive fine. but after some miles the check engine light will go out.
thanks
Could be overheating and coding out the TCC from engaging. Hopfully a Moderator will move this to the Transmission topic section for fitting attention. And yes, pull the code and cough up a little more background to get legitimate replies.
