1 - 1 of 1 Posts
O.k i'm not a wrench so bare with me.... Went in to work A/C was blowin cold...went out at lunch A/C is blowin hot air.. I got a re-charge kit to see if a can of freon will make a difference. Compressor is not coming on so i pulled pressure sensor and jump put a jumper across the wires to turn on the compressor but still nothing. I loosened the hose on the can of freon to see if its engaged and it comes out fine? What should i check next... ;( dead compressor?
1 - 1 of 1 Posts
