Hey guys, I'm pretty much at my wits end here. As stated in the title I don't have a key for my lugs. I belive the the wheels are GM Factory. Although I'm not possitive as I can't get them off to look for the stamp. Do any of you guys have a key I could buy from ya if you don't need it? I've talked to a lot of people on ways to get the lug off w-out a key. I tried pounding a socket over the lug. It did nothing. I even tried an air hammer. The "Kit" from sears only made a ring around the lug as it cut into the aluminum (pissed about that) It didn't cut or grab the lug at all. I don't think thier is enough of the lug protruding out. Oh, by the way these are the 94-96 style wheels. Any other suggestions thoughts? I need to change breakpads and can't get these damn things off! HA, sorry for the yelling....
Kenton
i know you suggested it, but when I bought my wagon had no key!
I beat a impact socket over them, than got them right off with an impact gun.
did no damage to wheel either
What size impact socket? And how did you get enough force to hit it on? I've tried every angle possible. I can't get a decent hit. The air hammer just rattled the socket around and chipped the lug. The problem I'm running into is the sidewall of the inpact sockets. Thier thicker than a regular one and I can't seem to get one over it.
I'm sure they must make lugs stronger than 30 years ago, but I got two off my BIL's Vega after he rounded them off using the wrong wrench. I made him pay for a few different sized chisels that I could orient to get the best bite - beat big divits into the lug first - then took to slowly backing them out. I used heat and WD40 too. Took a while, but I kept them chisels - still got'em. cwm1
You can Dremmel a land into them too and do the smack out that way I guess.
on my tahoe same problem...talked to a local wheel shop and made like 4-5 trips to get the right key...and nothing so they suggested a hammer and socket...so we had to hammer a socket and it did the trick
Try a 12pt 1/2 drive chrome socket -- maybe size 18mm or 19mm
Mr. -Clone,
It's been 5 days - waddidjado?
