replaced 2 times.Icm.
i love you you fellow round man...i needed that diag...http://shbox.com/1/95_ign_system_schematic.jpg
The fuse "callout" is the same for the b body. The same schematic is also used. Other than that you might need to go after the ign switch wiring. The ign power buss in the underhood panel gets its power through the passenger side firewall passthrough connector from the ign switch
Chris
none yet....updates?
...did you trace this wire??noticed a wire was spliced into the coil wire and runs up under the dash....didnt have time last night to trace the wire, however that wire has been there for years and it has ran...
Hmmm... good idea to check the iginition, but the kill switch tied into it hasn't worked in a couple years....did you trace this wire??
may have been a kill switched scabed in...and is now f#$&ed up....
