·I have a buddy that has a 94 Caprice that we are having problems starting. It will crank but will not start. We are not getting a spark from the wires at all. Replaced full pump with no fix, replaced ignition coil no fix, replaced ignition module no fix. Switched computers out in the cars and still nothing. I then tried to check for trouble codes but with datamaster program but it was unable to connect to pcm. I then checked the fuses in the underhood fuse box. We are not getting power to the PCM/IGN fuse on either side. What would cause the pcm not to get power? Is there a way to jump power to this fuse or reroute it?
