Tests from every OPTI no start thread.
No tool tests:
listen for the fuel injectors.
Smell for raw gas at the tailpipe.
Check the OPTI to sparkplug fireing order.
Easy tests:
Use a sparkplug to show spark is getting to the end of a sparkplug wire.
Or connect sparkplug at the coil wire to see if there is spark from the coil.
Easy tests with special tools:
Put a noid light on a injector wire.
Put a fuel pressure gauge on the fuel rail.
Checks with a live data scan tool:
Do you have a OPTI code?
Do you have live data RPM when cranking?
Tests with a multimeter from:
OPTI and Spark Test
Test with a spare OPTI:
And once you have your old opti back in hand, use it to test:
- Disconnect your fuel pump harness at the back of the car (driver's side behind bumper).
- Disconnect 4-pin wiring harness from passenger side of new optispark.
- Connect 4-pin harness to your old optispark.
- Turn the ignition on but don't start the car.
- Spin the old optispark by hand. If you hear the injectors clicking, you know that the 4-pin harness circuitry is good.
sherlock9c1
