1994 Caprice no start, i got spark(pulled wire off #1 stuck another plug in it and it arch when i tried to start it) and i got 40psi at the fuel rail but no start battery is draining over a few days time. i use my truck to jump it off and it will turn over but no start. Help Please. i Just swapped the motor in a few month ago for a friend and it has been sitting for a couple months waiting for him to get it. Now he wants the car and i can't get it to start.
The car has run since the swap. there are no aftermarket pieces wired in, the engine came out of a car with remote start but was removed before the swap. i am thinking opti or a ground but what gets me is that i have spark and getting fuel.
spark only proves the coil/opti is sending a spark to that specific plug what if u have 7 other bad connections(dought it just trying to prove the point)
does it crank hard?
check the grounds on the coil and other main grounds, if those are good swap out a working opti and see what happens.
You have spark & fuel, next would be air....is the MAF ok? is the intake track sealed good, I know when my 'plug' for homeplate popped out my car wouldn't run.
Is it a strong spark? Strong meaning visible in daylight. Check several plugs as mentioned. Did you check FI relays?
the spark was visable in daylight under the hood. i will check the FI relay this afternoon. as far as the intake the maf is good intake sealed i even unplugged the maf and tried.
