I have a 91 Olds CC with a L03. I am at a loss to figure out my start problem. The car chugged to a stop, and the starter would only turn the engine slowly. I pushed it to a parking lot, and the starter solenoid will not engage. On a couple of prior occasions it started and immediately shut off, restarted and it was OK.
I had the battery checked...good battery.
Tried to start in both park and neutral...no starter.
Replaced the ignition switch...no change.
Checked for voltage at the red wires to ignition switch...Voltage correct.
Loosened and retightened engine ground, and battery terminals.
Pulled the starter and had checked...good starter.
Reinstalled the starter but have not tested it yet.
Any ideas?
I am also concerned about the stumble to idle, but this may be an issue to deal with after I get it started again.
Another discovery...fuse 7 is melted on the bottom side. Anything?
Any ideas?
