ok, boys and girls,
got a 96 SS with the auto head lights, cool. Now at 140,000 miles, the damn tail lights wont come on while using it. Do it manual and all is well. Brake lights work regardless. Replaced head light switch at 104$. Looks nice. Didn't help. Fix this and I will send money. (not really, send you a nice head light switch)
There should be two fuses in the I/P fuse panel LPS and T LPS. Both are 10 amp. or the main fuse block fuse #14 15 amp. Check for voltage at the fuse block, if you have voltage there, and the fuse is good, then check the I/P fuse block
