I have a noise coming from the rear of the car, sounds as if the wheel is bouncing up and down. I have bilstien shocks, and new bushings. Is it possible that the the shocks are to hard? or bad shock? I have checked all the other bolts, everything is tight. I was thinking if it could be the fuel tank that might be loose on that side but it seems tight. does anyone else have this problem?
I had a clunking issue with my rear tires, I thought it was the rear at least. I replaced the caliper and the nosie isn't as bad as it was before. I don't know if this helps or not
