A
I get a lot of noise while listening to AM radio on my system. By 'noise', I mean static crackling. FM radio is fine and clear. Is there some way to make our stock antenna's pick up AM better, or is there a device to help stop the static?
I thought I heard someone talk about 'noise reducers' at some car show that you put somewhere to help this problem.
Thanks,
I had an AM reception static problem once on my old 93 wagon. Had to replace the antenna base. It was the fixed antenna. I heard that antenna components corrode, hindering the ground's effectiveness causing the static.
