about an hour each side it calls for, on a lift with airtools i can get them done in about 20min each.
as long as you have the tools its not bad, assortment of metric sockets and probably a 36mm axle nut socket.
with the wheel on and the car on the ground brake the axle nut loose- theyre usually between 150-200ft-lbs so use a big bar. jack her up and do one side at a time.
-remove brake caliper and ABS sensor if equipped
-Remove lower ball join nut and knock balljoint loose from control arm
-remove tierod end nut and knock loose and remove
--- tip for doing this, you can use a big hammer and with the nut off wack the side of the steering knuckle where the stud of the tie rod end pulls through. A few wacks and it usually pops loose without damage to the rod end- same can be done for the balljoin, jut dont hit the balljoin/tierods themselves or the threads
-fully remove axle nut
-lift up and out on the knuckle assemble and position off to the side while pulling axle end out of it
- take a prybar and go between the axle end and transmission and pop it out
to install reverse procedure. put some trans fluid on the new axle end to put it back in the trans a little easier it can sometimes be a pain to get the retaining clip thats on the end to compress while pushing it in
and the whole axle will fit through the horseshoe on the bottom of the strut
