·Okay guys this year the “Festivus” starts early. We will be running these specials from now through December 15, 2006. There is truly something for everyone.
Comp Cams Self Aligning Pro-Magnum Roller Rockers:
CC-1318-16 $279.97
CC-1317-16 $279.97
Comp Cams Non-Self Aligning Pro-Magnum Roller Rockers:
CC-1302-16 $259.97
CC-1305-16 $259.97
Comp Cams “Beehive” Valve Springs
CC-26918-16 $151.97
CC-26915-16 $151.97
Comp Cams “Beehive” Valve Spring Kit (includes springs, retainers, locks, seats*, valve seals)
Kit For Iron Cylinder Heads $211.96
Kit For Aluminum Cylinder Heads $239.96
*aluminum heads require spring seats
EX-614KCM Valve Springs Kits $99.97
All LT1 Hydraulic Roller Camshafts $249.97
Trick Flow 195cc LT1 Cylinder Heads $1274.97 (pair)
Heads-Cam Package $ 1799.97
Trick Flow Cylinder Heads
Comp Cams Custom Grind Camshaft
Comp Cams Pro-Magnum Roller Rockers
Hardened Pushrods
If you have any questions or need something different please send me a pm.
Thank you,
Sam
CC-1318-16 $279.97
CC-1317-16 $279.97
CC-1302-16 $259.97
CC-1305-16 $259.97
CC-26918-16 $151.97
CC-26915-16 $151.97
Hardened Pushrods
Thank you,
Sam
