There is no minimum number of orders needed. Shipping is FREE for the Nitrous Kits OR if you order 2 or more accessories it will be free. It will be $5 shipping if you order just one accessory. (48 states only, AK, HI, and International contact for shipping cost) Most stuff is in stock, if not instock it will only take 2-3 days to get. Ordering info is below all pricing. Any questions just post or contact me.
ZEX
ZEX "SMART" NITROUS SYSTEMS
82011 ZEX "Dry" Nitrous System 55-75hp $475.00
82011P ZEX "Dry" Nitrous System 55-75hp, POLISHED BOTTLE $537.00
82012 ZEX "Dry" Nitrous System W/O Bottle $305.00
82014 ZEX "Dry" Nitrous System for Nissan $475.00
82014P ZEX "Dry" Nitrous System for Nissan, POLISHED BOTTLE $537.00
82015 ZEX 5.0 Ford Nitrous System $475.00
82015P ZEX 5.0 Ford Nitrous System, POLISHED BOTTLE $537.00
82016 ZEX VW 2.0 Nitrous System $475.00
82016P ZEX VW 2.0 Nitrous System, POLISHED BOTTLE $537.00
82017 ZEX 5.0 Ford "Dry" Nitrous System W/O Bottle $315.00
82018 ZEX LT1 Nitrous System $578.00
82018P ZEX LT1 Nitrous System, POLISHED BOTTLE $637.00
82019 ZEX BMW Nitrous System $475.00
82019P ZEX BMW Nitrous System, POLISHED BOTTLE $537.00
82021 ZEX "Wet" Nitrous System 55-75hp $515.00
82021P ZEX "Wet" Nitrous System 55-75hp, POLISHED BOTTL $575.00
82023 ZEX "Wet" Nitrous System 75-125hp $515.00
82023P ZEX "Wet" Nitrous System 75-125hp, POLISHED BOTTLE $575.00
82026 ZEX "Wet" LS1/LS6 Nitrous System 75-125hp $515.00
82026P ZEX "Wet" LS1/LS6 Nitrous System 75-125hp, POLISHED BOTTLE $575.00
82030 4 Cyl. Direct Port Nitrous System (55-175hp) TBA
82040 4-Barrel Plate Nitrous System (100-350hp) TBA
82121 ZEX Nitrous Fill Station $737.00
ZEX NITROUS SYSTEM ACCESSORIES
82010 ZEX Nitrous Purge Kit $91.00
82170R ZEX Nitrous Purge Cloud Illuminator Kit (red) $58.00
82170G ZEX Nitrous Purge Cloud Illuminator Kit (green) $58.00
82170B ZEX Nitrous Purge Cloud Illuminator Kit (blue) $58.00
82009 ZEX Remote Bottle Valve Opener $192.00
82006 ZEX Nitrous Bottle Heater $103.00
82005 ZEX Nitrous Pressure Gauge & Manifold $41.00
82003-4 ZEX Spark Plug, Set of 4 $25.00
82003-6 ZEX Spark Plug, Set of 6 $31.00
82110 ZEX Safety Blow Down Kit (internal thread style valve) $34.00
82111 ZEX Safety Blow Down Kit (external thread style valve) $34.00
82100 ZEX Maximizer Kit $194.00
82100P ZEX Maximizer Kit, POLISHED BOTTLE $270.00
82020 ZEX Booster Fuel Pump Kit $154.00
81021 ZEX Dry to Wet Conversion Kit (55-75hp) $300.00
81023 ZEX Dry to Wet Conversion Kit (75-125hp) $300.00
82000 ZEX Nitrous Bottle W/Valve $182.00
82001 ZEX Racer's Tuning Kit $261.00
82002 ZEX Nitrous Switch & Cover $24.00
82007-1 ZEX Nitrous Controller Box (Dry) $257.00
82008-1 ZEX Nitrous Controller Box (Wet) $267.00
82009SW ZEX Remote Bottle Valve Opener replacement switch $19.00
82013 ZEX Bottle Bracket Kit $25.00
82025 ZEX Replacement "Wet" Nitrous Nozzle $69.00
82099 ZEX Safety Blow Down Kit (fits all valves) $48.00
82108 ZEX Programmable TPS Switch $70.00
82143 ZEX Ejector Air Amp., 2.50 in. diam., 4 ft. hose $69.00
82144 ZEX Ejector Air Amp., 2.75 in. diam., 4 ft. hose $69.00
82145 ZEX Ejector Air Amp., 3.00 in. diam., 4 ft. hose $69.00
82146 ZEX Ejector Air Amp., 2.50 in. diam., 6 ft. hose $69.00
82147 ZEX Ejector Air Amp., 2.75 in. diam., 6 ft. hose $69.00
82148 ZEX Ejector Air Amp., 3.00 in. diam., 6 ft. hose $69.00
82000C ZEX Carbon Composite Nitrous Bottle W/Valve $497.00
82000P ZEX Polished Nitrous Bottle W/Valve $255.00
82122A ZEX Nitrous Fill Station air seal rebuild kit $55.00
82122H ZEX Nitrous Fill Station hyd. seal rebuild kit $100.00
ZEX DATA ACQUISITION SYSTEMS
Z50180 ZEX 4 Cyl. Data Acquisition System $3,535.00
ZEX T-SHIRTS
Z106-XXXL ZEX XXX Large T-Shirt $20.00
Z106-XXL ZEX XX Large T-Shirt $19.00
Z106-XL ZEX X Large T-Shirt $19.00
Z106-L ZEX Large T-Shirt $19.00
Z106-M ZEX Medium T-Shirt $19.00
Z106-S ZEX Small T-Shirt $19.00
NX NITROUS EXPRESS
NX #20001-10 Hitman EFI Single Nozzle System 35-50-75HP - $440
NX #20920-10 Stage 1 GM EFI Wet Kit 35-50-75-100-150HP - $519
NX #20921-10 Stage 1 Dodge EFI Wet Kit 35-50-75-100-150HP - $519
NX #20922-10 Stage 1 Ford EFI Wet Kit 35-50-75-100-150HP - $519
NX #20923-10 Stage 1 Import/Universal EFI Wet Kit 35-50-75HP - $519
NX #80004EFI-10 4Cyl Direct Port Kit 50-75-100-150-200HP - $615
NX #80006EFI-10 V6 Direct Port Kit 60-90-120-150-200-250HP - $675
NX #80000EFI-10 V8 Direct Port Kit 100-150-200-300-400-500HP - $750
NX #20000-10 Intercooler Chiller Kit - $368
NX #15600 Purge Kit - $107
NX #15509 Pressure Gauge - $49
NX #15940 Bottle Heater - $203
NX #15939 Bottle Heater with Pressure Gauge - $226
NX #11107 Remote Bottle Opener - $223
NX #Gen-X Upgrade kit includes, Bottle Heater, Pressure Gauge, EFI Fuel Press. Safety Switch, Blow-down tube, and NHRA pipe away fitting - $298
NX #GenX-2 Upgrade kit includes all of Gen-X + Purge Kit - $372
NX #15531 2 5/8 Nitrous Electric Pressure Gauge with Sensor - $239
NX White Bottles
11021 7 Oz Bottle - Motorcycle Valve - $114
11022 10 Oz bottle - Motorcycle Valve - $114
11010 16 Oz bottle - Motorcycle Valve - $118
11023 1.4 Lb bottle - Motorcycle Valve - $138
11025 2.5 Lb bottle - Motorcycle Valve - $141
11055 5 Lb bottle - Standard PF Valve - $156
11100 10 Lb bottle - Standard PF Valve - $212
11101 10 Lb bottle - Pure-Flo 100HP+ Valve - $254
11152 12 Lb Composite bottle - Pure-Flo 100HP+ Valve - $459
11150 15 Lb bottle - Standard PF Valve - $264
11151 15 Lb bottle - Pure-Flo 100HP+ Valve - $314
All 1.4 Lb and larger bottles are also available in Show Polished, except 12 lb Composite bottle.
VENOM
Venom VCN-500 Recluse - $355
Venom VCN-1000 - $565
Venom VCN-2000 - $1100
MANUFACTURERS SITES
We carry the whole line of all of these brands. So check out their site and let me know what part number you want and I will get you a price.
Nitrous Express -
http://www.nitrousexpress.com/
Nitrous Works -
http://www.bgfuel.com/nitrous/default.aspx
NOS -
http://www.holley.com/nosnitrous/index.html
Texas Nitrous Technology -
http://www.texasnitroustechnology.com
Venom -
http://www.venom.com/
Zex -
http://www.zex.com/
ORDERING INFO
You can order with a Credit or Debit card, just call me at 1.434.454.4469. We can take Visa, MasterCard, American Express, or Discover from US addresses only and can only ship to the billing address.
You can also pay with a money order, certified bank check, or personal check. Just go to
http://www.importcarpartsplus.com/mailorder.htm Payment must clear before shipping.
You can also pay with PayPal to
[email protected] as long as you have a US confirmed address.
If you have any questions or need anything else for your ride just let me know. We have access to over 1000 brands.
Justin DeMatteo
Import Car Parts Plus
[email protected]
AOL Instant Messenger - SmoothGalant2
Phone 1.434.454.4469
Mobile 1.434.470.4469
Fax 1.434.454.6942
