I have a Roadmaster hvac climate control unit in my 94 Fleetwood and love it.
But now i want the cc in my 96 obdii Fleetwood.... I'm concerned a obd1 cc from a RM 94 or 95 will not work especially diagnostics.
Any Fleetwood owners out there can attest either way?
Good question. Don't know the answer. RM HVAC is awesome. If it does matter, why not just use one from a OBDII donor car? Shouldn't be much harder to find than from OBDI.
You could run it through a few tests and see how it does. Tach, speed, coolant temp etc.
Then disconnect a sensor, get a code, and see if you pull it properly.
Of course you could swap in an OBDII unit. Did your car originally have an OBDII CCM?
I don't even know if the plug would be the same.
I have a lead on an obd1.... Want to see if anyone verified it works or not since this is easiest to get at the moment. Just seeing if anyone knows for sure.
