That codes sucks, it's a random misfire on one of the 8 cylinders.
you got any other symptoms ?
-ALF out...
Banned
well this can be the ignition coil .. or the opti ..this will create a 300 code.. this is your only issue ? if so then this may help.
did you drive it in a car wash ? drive thru deep puddles or heavy rain @90MPH ?
then that maybe the opti .. if not then the coil if 23 yrs old replace it.
plug wires can cause miss fires but not all cylinders miss firing .
you didn't use Bosch O2 senors i hope ?
When you clear the code, does it come back after car warms up and goes into closed-loop or right away in open-loop when motor is still warming up ?
I would pull the plugs and see if any look fouled from rich or lean condition, if i did not know where to start.
-ALF out...
