·I get this kinda grinding noise from the RF at slow speed. It goes away after I apply the brakes a few times or turn sharply in a parking lot.
Sometimes I even hear this sound when I am off the brakes and just creeping along in traffic at say 5mph. Its a low grinding kinda noise, kinda like a tire rubbing on the sway bar.
The car also pulls to the right under braking and sometimes will want to turn to pull to the right alot when I am on the gas.
I know the rotors and pads are just about trashed because Under high speed braking The front brakes are real noisey and hum. There is now play in the front wheels so I would think the wheel bearings are allright.
Perhaps this weekend Ill check this out if its warm.
I think Ill buy 2 new GM ones if they are not really expensive.
Thanks.
Im Def. a novice at this... It would be the first time I would be replacing the calipers.
Thanks.
