10-4 on that kink96ss, there is one 7mm bolt on the left side fuse panel box, a few at the botton, and one when you slide the ash tray out it is up under neath there below the radio. After you have the black brezel off you just pull it off. There is one wire that is for a light in the ash tray you have to carefull with, other than those two hidden bolts it's easy. Hope this helps, if not who cares I have nothing to do any ways.
Kevin
