Purchased and installed the odometer repair kit from NAISSO. Started the car and the display lit up nice and bright, but displayed 999999 as the odometer reading instead of 87xxx. Any ideas, please help.:confused:
You most likely dribbled solder across two or more circuit strips or you broke the contact of a strip. Remove the cluster and closely inspect your work.
Still No Good
Checked soldered joints....they looked fine. Same problem..odometer lights up bright, still displays 999999.:confused::mad:
