THis message relates to odometer on 96 Impala SS. A few years ago the odometer went blank. I took out the cluster and I applied the NAISSO fix and installed the resistor unit as described here and all worked fine. Recently, the odometer went blank for a few minutes while driving. I shut the car off at home, when I started it again, the odometer came back but with invalid mileage. The correct mileage was about 115,000, it came back at about 83,000 and something. It is working, clicking off miles from there. The Miles/KM works and the trip meter resets and works correctly.
So it works but not correct mileage. My concern is that the inspection sticker on the car has the old mileage and when I get the car inspected later this year, questions will arise. Also, I have maint records with mileage recorded, and now will have maint records with incorrect mileage. Kind of suspicious when I try and sell the car.
Any ideas on how to fix ?? Are there contacts for the odometer I can clean with isopropyl alcohol or is it a re-solder job somewhere ??? I assume the mileage is correct in the PCM but the display is wrong.
Thx for any and all help. RIck
