1 - 12 of 12 Posts
I'm throwing a 70 455 in my skylark and I know that our cars run pretty hot. I'm thinking it might work for me. I would like to use an electric fan and radiator setup taht I have lying around from a caprice.
Any smart guys have any insight on this because I'm a big dummy
they are kinda small i would go with an after market.
Big blocks can get hot. I don't think a caprice radiator will do the job.
I had problems with the stock (120k miles on it) radiator and a 420 rwhp 383. BeCool radiator reduced the temperatures by approximately 25 degrees in hot weather at low speeds.
As an alternative, AFCO makes some nice al. radiators. I got one of their dbl pass al. radiators to keep my BBC cool for around $250.
I run an off the shelf traditional 4-core radiator in my 464 Buick, rockauto had it CHEAP.
They do like to run hot, so make sure you've properly shrouded the fan(s), timed it, run water-wetter and have a low T-stat in it to keep things flowing cool. If you happen to HAVE a stock rad laying around, throw it in if it fits to try it out... just keep an eye on that temp gauge. I know it wouldn't fit in my '66 chassis' rad support, a lot didn't. I ordered one of those "universal" Aluminum Radiators when I first swapped for BBB.
V8buick.com has a wealth of information for that stuff, if you're not already on there. Good group.
Yeah I'm on v8 buick
Im doing 350 to 455 swap.
Just weighing my options
Discussion Starter · #9 ·
Thanks for the rock auto tip !
ordering a radiator from there
Stage 1 heads and monster T/A cam it.. MUUAAAHAAHAA!!
Im still dreaming of the day i drop a 455 into my 68.
..sorry.. im no help... just got excited for a bit... carry on..
Gotta love the Buick 455. Are you running the Stage 1 heads?
With any big block buick the Caprice radiator will NOT keep it cool enough. The old GS Stage 1's tended to run a little warm when new from the factory. I wouldn't even try to run a stock GM unit. Go straight for an aftermarket aluminum radiator, low temp thermostat, and the best water pump you can find.
I'm +0.40 overbore and running fully ported '70 Stage 1 iron heads, 11:1 compression and a non-clutch fan through a radiator that wasn't intended for it with no issues. I wouldn't worry about too much, just keep an eye on it.
In this past summer's 90* heat, the car idled in traffc at 170.
1 - 12 of 12 Posts
