1 - 16 of 16 Posts
Welp I picked up a 1996 RMW a month or so ago and now I bought MSD wires, and distributor also got the timing gasket kit...
problem now is that gasket on the bottom of the timing cover. I went out and got the fel-pro gasket.
Now I am having a hell of a time getting the oil pan off...
I got the starter out and the oil cooler...
Any tips and or advice??
Not an easy job but some basics that need to be done......
You need to position the engine to number 6 TDC to align the crank.
You need to remove the oil level sensor in side of pan.
You need to raise the engine about 3 or 4 inches.
Obviously a lot more to this process. Try doing a search here for more info and best to pickup a Haynes or Service Manual which will walk you through the process.
Thanks for the info, welp iI didn't take out the sensor ripped that sucker right out :mad: and I am unsure of how to get it TDC...I tried like hell to search but came up wwih nothing...
If someone could post a like that be sweet...
Pick up a Haynes manual for about $20 and it actually has a decent write up on the process. As for TDC, I believe the pointer on the balancer at the 12:00 position is an indication of #6 or #1 TDC. So if that is pointing up, you have the crank where it needs to be.
If you dont want to bother with a new "leak prone" sensor you can just use a plug. I got one with a magnetic tip and used that instead. I then shorted the 2 leads of the sensor pigtail and wrapped it out of the way. I prefer the dipstick method of checking my oil. :)
BTW - I just did a quick search on "Oil pan removal" and it brought up a couple of pages of stuff. So it does work it you dig through the posts a little.
The 2nd post in this tread has some good, basic info on this but try to grab a manual for the specifics. I also remove the inspection cover from the trans for a little more clearance removing the pan and did not remove the dip stick tube.
http://www.impalassforum.com/vBulletin/showthread.php?t=258990&highlight=oil+pan+removal
While you are in there, put a new oil pump to cam drive connector in. Get a metal one, the nylon ones tend to get brittle and crack...no more oil pressure.
I one reads the GM service manual, they would find this info partially incorrect .
Yes cast pointer up is 1 and 6 TDC ,however, this is not the best position to remove the oil pan as the crank counterweight interferes with pan removal .
If the cast pointer is facing straight down, the gap between the counter weight and the crank pin is down, affording the most clearance to re&re the pan .
So as per common sense AND the factory service manual ,
The best position for pan removal in the car is
Cast pointer on hub down (6 o'clock) which is cylinder 1 & 6 BDC
The one problem with the LT1 is the hub is not keyed and , although not a functional problem , it can be miss positioned and often is when crank seals or timing chains are done. Then the cast pointer can not be used as reference.
That might be, as I mentioned that was from memory and thought there was a "6" in there somewhere. :). So maybe it is 6:00 position for the pointer.
the Haynes manual does mention this and for $20, its a good investment for this and other repairs too.
Hey guys! After reading this thread I removed the harmonic balancer, the hub and timing cover with out marking where the pin was on the cranks will this be a problem? It sounds like it might be! Is there anyway I can position it right for installation using the dowel pin on the camshaft sprocket?
Sorry for reviving this thread I know it from last year.
You could just alighn the dots on the Timing Gear Set which should (I believe) put you at 1 or 6 TDC. Or pull the Rocker Cover and look at the valves clowsing on the 1 Cylinder
IIRC - when I removed my hub, there was almost a mark of some sort on the inside where the slot is in the Crank for a Key. You should see a Stain or marking on the inside of the hub that should get you in the ball park.
Speaking of the key, it is recommended you install a new hub that uses a key or have yours machined so that you can use a Key. This will prevent the Hub from spiining on the Crank. I did not do this at the time I reinstalled mine and I've been OK so far without it. Just something to consider.
4DoorSS thanks for replying I was just looking at some pics I took of the gears but I can't seem to identify the the dots you are talking about but I will have to check it personally on the car. ALSO regarding the "key" your talking about the woodruff key correct? And if I buy a new hub (which I was already planning on doing) I don't require to machine I could just easily install with no problem?
Yes, that would be a woodruff key. I just did a Search "woodruff key" and happened to find this thread. :)
http://www.impalassforum.com/vBulletin/showthread.php?t=269740&highlight=woodruff+key'
I had similar concerns as yours getting it back on there correctly. But as I mentioned and I believe Rocko did as well, there should be some discolorization inside the hub reavealing sort of where it sat before.
The aftermarket kits that are out there usually have a Hub, Key and new balancer. they will most likely include assorted washers as the different LT1 cars (Camaro, Vette, Caprice) have different spacing needs for accesories differences. Be sure to get a kit that is compatable or maybe just consider machining your old hub as Rocko did. I wish I had did mine but my next upgrade will just be a new Balancer setup as I hate the ugly stocker and yes the Aftermarket Hubs are usually slotted for this already.
1 - 16 of 16 Posts
