R
ok, I could swear that the oil pressure sender is allways near the distributor on a small block. I need to change mine to the roadmaster sender, but can not seem to find the damn thing. I had the flashlight out and everything. I could not see very well due to the distributor cap and plug wires, but I felt around and I swear its not there. Where is it? My cheapo repair manual says nothing about it.
H
If it's like my '88 chevy truck, it'll be right above the oil filter like BBODYLTZN said, mounted on a 90 degree fitting. Behind the distributor, there SHOULD be a oil pressure switch for the ECM, to shut down the engine if oil pressure is lost. A little trivia for you. ;)
yep and its a beoch trying to find out what socket size to use i dont remember but it was a big one
