Okay guys....I hope someone can answer this.....I am running an Alpine CDM-7824....its an older unit that is also a changer controller. The best I can figure, the changer used for this unit was the 5960. Does anyone know what other units will function with it? A newer one maybe or am I stuck looking for an older one?
4
The way Alpine works, if I remember from the good old days is: If your head unit is a CDM-XXXX, you can run any CHM-XXXX changer with it. If for example you had a CDA-XXXX head unit, then it would be compatible with any CHA-XXXX changer. I have the venerable 5959 changer sitting on my shelf, and the 5960 was a variant of it. I'm not sure it will work straight up with your 7824 or not.
Hope this helps...
I'm pretty sure any M-Bus changers will plug right in.
Alpine also has an M-Bus to AI-Net adapter for about $10 that lets you connect the following changers - CHA-S634, CHA-S614, or CHA-S604. I got the info from Crutchfield's web site.
